RJW998
Sep 01, 2021Aspirant
Nighthawk app and no connectivity
I went to login to my laptop the other day and it would not connect. After checking, none of my devices that had worked fine the day before would connect even though there was a signal. I reset and r...
Sep 02, 2021Guru - Experienced User
Also, to clarify.
1. are devices saying "connected, no internet"?
2. is it broadcasting wifi but you can't even connect to it?
3. Is it not even broadcasting wifi at all?
4. do wired devices work?
Just trying to clarify what is actually happening.
RJW998
Sep 05, 2021Aspirant
Hi,
It is broadcasting a signal but devices cannot connect (2). Cable access does not work either.
- michaelkenwardSep 06, 2021Guru - Experienced User
How about answering these questions?
What is that modem?
When a device cannot connect, it usually throws up some sort of error message. These can help to diagnose what is going wrong.
And what does this mean?
You have cable Internet with a cable modem of some sort?
