hbk_seanmichael
Mar 02, 2022Aspirant
Nighthawk app keeps telling me I have no connection
I can't even get logged into my router because it keeps saying "no internet connection" when I try to log in. Even though I am connected and can use every single device in my house..... and for some ...
Mar 02, 2022Guru - Experienced User
what modem/gateway is the router connected to?
Try these ip addresses:
192.168.1.1
10.0.0.1
the first is the default and the 2nd is the default if theres an IP conflict/double nat on your network.
- hbk_seanmichaelMar 02, 2022Aspirant
It's the AP router on my network. 192.168.1.1 is my R7000 and I have the AP router R7000P with a static IP 192.168.1.2
- plemansMar 02, 2022Guru - Experienced User
that'd be the router/access point.
And are you able to access the router using its ip address?
