Taz14220
Apr 10, 2021Aspirant
Nighthawk AX3000 Bandwidth Problem on Ethernet ports only
Hi everyone, I got a problem I can't solve. My IPS just upgraded my service. I have Spectrum 200Mbs down 10Mbs up Cable service.... The service was just tested. I get 240Mbs down 12Mbs up from the mo...
- Apr 10, 2021
94mbps indicates it isn't connecting at gigabit speeds.
Have you checked you network connections stats?
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
that'll show you if you're connecting at gigabit speeds. It wouldn't be the first time an end was wired wrong and was connecting at 10/100mbps speeds.
Apr 10, 2021Guru - Experienced User
