jawad_AX
Dec 17, 2021Aspirant
Nighthawk AX3000 RAK40 bande 2.4/5GHz instable et redémarrage trop long
Bonjour, - J'ai une connexion fibre sosh avec une livebox qui me permet d'avoir un bon débit en wifi . cela fait presque 1 ans que j'utilise un ax3000. - rak40 comme point d'accés, il est relié...
Dec 17, 2021Guru - Experienced User
en anglais s'il vous plaît
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
jawad_AX
FURRYe38 I'm sorry, i'm not understanding, i was thinking that i share the topic in french community ! maybe there is noo french community ! but my topic is in nighthawk subject ?
- FURRYe38Dec 17, 2021Guru - Experienced User
I believe this would be the forum yoru looking for:
