DaveSiegler
Jan 28, 2022Initiate
Nighthawk AX3000
audio/video sync problem. I have Charter/spectrum coming to my modem & router via cable, but using wi-fi to my TV's. One TV is only 15 ft from the router, but I have a lag of 1-2 seconds between vide...
- Jan 29, 2022
Thanks for your reply. I finally called Charter and the person (American, no less) who answered knew I needed to reset Roku and that solved everything.
DaveSiegler
Jan 29, 2022Initiate
Jan 29, 2022Guru - Experienced User
Ok, if you mark it as solved, it might help prevent others from trying to fix it without reading it :)
thanks! Glad its working
