Bob1225
Dec 22, 2021Follower
Nighthawk AX5400
I just purchased and set up the Netgear Nighthawk AX5400, Model XR1000. I would like to know if the red panels on the front and top back by the antennas are suppose to glow or be lit..
You might get better results in the forum for your device.
Nighthawk Pro Gaming Routers - NETGEAR Communities
they might have a better idea.
here's where you can find manuals/guides for that device.
Nighthawk XR1000 | Pro Gaming Router | NETGEAR Support
Netgear has set up a community forum specifically for the NightHawk Gaming Router products. Most of the people who watch that forum are more likely to have experience with NH gaming router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routersReview the user manual to see if there is information regarding that.
Thank you.
