mnoah66
Mar 07, 2018Aspirant
Nighthawk blocking SlingTV
Hello all, Seemingly overnight, SlingTV is not working on any of my devices. I did a factory reset of the router and that did not work. I plugged my laptop PC directly into the ISP modem and Sl...
- Mar 09, 2018Sling is now working. I did not make any changes so confirms the issue was with Sling. Thanks everyone for the help!
Mar 07, 2018Guru - Experienced User
What is the Mfr and model of the ISP modem? Built in router by chance?
jsputrawrote:I'm having the same problem which not allowed to connect the Sling TV through nET GEAR Nighthawk, I tried to connect to modem directly and it works.
Tried to connect using VPN and it works too.
JS
jsputra
modem Arris TM822
- FURRYe38Mar 07, 2018Guru - Experienced User
Is uPnP enabled on the router? Should be enabled.
Try setting NAT Filter from Secure to Open. Save settings. Power down the Sling device/app. Reboot the router fully. Then try the service again.
- jsputraMar 07, 2018Aspirant
uPnP enabled
NAT Filter from Secure to Open. OPneed already
Saved and restart the apps but still no luck.
it works for 1 weeks.
This problem starting this morning.
Great, thanks for trying anyway.
I just called Sling Support again just now.
I'll keep you posted.
For now will use VPN for Sling.
