mnoah66
Mar 07, 2018Aspirant
Nighthawk blocking SlingTV
Hello all, Seemingly overnight, SlingTV is not working on any of my devices. I did a factory reset of the router and that did not work. I plugged my laptop PC directly into the ISP modem and Sl...
- Mar 09, 2018Sling is now working. I did not make any changes so confirms the issue was with Sling. Thanks everyone for the help!
Mar 09, 2018Guru - Experienced User
Glad Sling got it working.
Enjoy. :smileywink:
mnoah66wrote:Hello all,
Seemingly overnight, SlingTV is not working on any of my devices. I did a factory reset of the router and that did not work. I plugged my laptop PC directly into the ISP modem and SlingTV worked. Somewhere along the lines of the Nighthawk Router is SlingTV not working. I've contacted both SlingTV and my internet service provider. I've confirmed that my SlingTV account is working as I have no issues when using cellular data or from a different ISP/router altogether (relatives in another state).
I've seen some bits and pieces of help online, but nothing clear cut. It seems that I may have to do some port forwarding on my router, but I have no idea what port. Besides, that seems a bit overkill for what should be a simple service aimed at non-tech customers.
Any help is appreciated and I can provide quick feedback of solutions proposed!
Best,
Martin
