wz5257's avatar
wz5257
Nighthawk C7000 Comcast Extreme Pro 400Mbps - not getting the speed
I had xfinity Blast Pro Internet service and was getting 200-220Mbps download speeds.  I just upgraded to Extreme Pro, their 400Mbps service, but can not get more than the 220Mbps speed with my C7000...
  • michaelkenward's avatar
    michaelkenward
    Mar 27, 2018
    wz5257 wrote:
    I run it from an iPad Pro and Macbook Pro, both with 802.11ac wifi capability.  The traffic between either of those devices and my C7000 should be able to get above 400Mbps, right?
    Unlikely. Wifi speeds are not the same as wired speeds. A wired connection could get as near as possible to the speed that the internet service delivers. Wifi? Some hopes.
    The speed you get depend on many things, including the capabilities of the wifi clients and the wifi source.
    I would forget about the router and do some research on the speeds that I could expect from my wifi clients. These sites, for example:
    802.11ac vs 802.11n - What’s the difference between the Wi-Fi standards? | Trusted Reviews
    How Fast Is a Wi-Fi Network?
    suggest that your wifi speed is pretty near the expected limit for 802.11ac.
