victorgonzalez
Oct 05, 2020Tutor
Nighthawk C7000 USB to Canon MP210 doesnt work
Hello, I am trying to setup my Canon MP210 as a wireless printer. I connect the USB-A to USB-B into the Router USB port, sometimes it shows as a connected device. But I cannot see it in the NetGe...
- Oct 09, 2020
Suddenly it worked. I didnt do anything new. Maybe a computer reset.
Thank you for your help!
Oct 05, 2020Guru - Experienced User
Page 50 of the manual goes over installing a usb printing device. have you walked through all the steps?
you can find the manual here:
https://www.netgear.com/support/product/C7000
there's even a usb printer guide here:
https://www.netgear.com/support/product/ReadySHARE_USB_Printer.aspx
- victorgonzalezOct 05, 2020Tutor
Hello Plemans,
Thank you for your reply and help. I've already done those steps. Even disabled the firewall on the router and allowed the NETGEAR USB Control Center through my laptop's firewall and no result.
Now I dont see the printer on the router.
This is so weird.
Victor Gonzalez
- plemansOct 05, 2020Guru - Experienced User
have you tried running the usb control center as an administrator?
If you log into the router through the browser, does it show the printer connected?
Hello,
Yes, I've tried to open the NETGEAR USB Control Center as admin and no luck. But I see the printer connected. Please see screen attached.
