bsrosell
Jan 12, 2022Tutor
Nighthawk c7000v2 will not work with OpenDNS
hi, just got Xfinity and the Nighthawk C7000v2 modem/router, and have been trying to set up OpenDNS like I always used with my old Century Link system. I followed OpenDNS instructions, added the DN...
Jan 12, 2022Guru - Experienced User
instead of disable ipv6, are you setting up the dns settings to run of opendns's settings?
What actual settings do you have in the router for the opendns? (screen snips help, black out you mac info)
bsrosell
Jan 12, 2022Tutor
thanks; used the two recommended (and that I've used in the past). Since there is a third row (Tertiary) here, I also tried filling that in with the secondary DNS address, but that doesn't work either.
(can't figure out how to paste my "snip" in here, but attached as a file).
For the IPv6 aspect, I simply went to the Advanced tab and IPv6, and selected "Disable". There isn't anything to tell me it is now on IPv4 but what else is there??.
Use These DNS Servers
Primary DNS 208 67 222 222.
Secondary DNS 208 67 220 220
Tertiary DNS .. currently blank, but tried 208 67 220 220 per OpenDNS helpdesk; that didn't work either.
