bsrosell
Jan 12, 2022Tutor
Nighthawk c7000v2 will not work with OpenDNS
hi, just got Xfinity and the Nighthawk C7000v2 modem/router, and have been trying to set up OpenDNS like I always used with my old Century Link system. I followed OpenDNS instructions, added the DN...
Jan 12, 2022Guru - Experienced User
Not sure if the C7000 actually support disabling ipv6. have you logged into the router to see if you can disable it?
IPv6 can be something set by the ISP with modem/router combo devices.
bsrosell
Jan 21, 2022Tutor
Yes, everything done within the Netgear Genie menu.
I called Xfinity, NO help (must be Netgear's problem).
Called Netgear, wouldn't even talk to me since 90 day warranty up (even though only had it for a month thanks to Xfinity taking 3 months to bury my cable!). So, finding no other answers, I guess I punt on OpenDNS (their helpline suggested same), and try Cloudflare or something for filtering. That is all I'm loooking for. Thanks!!
