Timlab55
Oct 15, 2021Guide
Nighthawk C7800-200
I have two gateways. The first is an ARRIS BGW210-700 which is from ATT, and the second one is a Nighthawk C7800-200. I would like to connect my Nighthawk to my BGW. I do know that i have to put m...
Oct 15, 2021Guru - Experienced User
C series modems can only be connected to Cable ISP services that support Coax cable line connections.
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
