island_dave
Mar 12, 2018Aspirant
Nighthawk cannot factory reset after firmware update and reboot
Hi everyone, Having an issue - did a firmware update on Mar 11, 2018 to latest version. It loaded fine and rebooted the router - then router would only boot until power light flashes amber - and doe...
- Mar 12, 2018
Hi and thanks for the quick reply!
I have read so many threads and done so many things - only one worked just now so thought I would share the good news.
Solution was to connect via LAN with a Win10 laptop set at 192.168.1.10, subnet 255.255.255.0 and default gateway 192.168.1.1.
From command line, set it to ping -t 192.168.1.1 - and reboot router. Make sure all is pinging fine and wait about 2-3 minutes. At this point, as with every other reboot - power light flashes amber as always.Now, instead of using the TFTP2.exe software as per Netgear article (which did not ever work), I did the following:
In win10, control panel, add windows features - i added/installed TFTP (this is an OS component, not a third party program).
Once installed, I opened a Command Prompt with administrator rights.I ran the following command:
tftp -i 192.168.1.1 put R8000-V1.0.3.4_1.1.2.chk
(change the firmware file name to match the latest you downloaded and unzipped)
This then said transfer successful - and while it was doing it I noticed the power light stopped flashing and stayed solid amber (for the first time so knew something different happening). Router then rebooted a few times and I just left it until a few minutes later when all was up as normal, all lights regular color, and we were back to factory settings!!
Hope this helps!
Dave
Mar 12, 2018Guru - Experienced User
Try this process:
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
I presume if this fails then I would contact ChristineT and see if she can help you. There was one other that experience similar issue in recent FW udpate.
I recommend using IE11 or FF browsers when upgrading FW as well. Seem chrome cause problems here and there.
- island_daveMar 12, 2018Aspirant
Hope this helps!
Dave
- FURRYe38Mar 12, 2018Guru - Experienced User
Glad you got it working.
Maybe that article could be updated to include Windows 10 information.
Thanks for letting us know. Glad it's working again.
Enjoy.
