akeele
Oct 26, 2021Star
NightHawk CAX 30 slows until Factory Reset or config restore
I have experienced this issue with this router since buying it at Costco in July 2021. My firmware is up-to-date with version 1.4.10.8. I do not have any special port forwarding or access control con...
Oct 26, 2021Guru - Experienced User
For your future CAX needs, Netgear has set up a community forum specifically for the Orbi With Cable Modem products. Most of the people who watch that forum are more likely to have experience with Orbi with cable modem and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
akeele
Oct 26, 2021Star
You are recommending I post to a specialized Orbi forum described as "All things Cable Orbi, including updates, tips, & more" regarding my Nighthawk CAX30 cable modem?
- FURRYe38Oct 26, 2021Guru - Experienced User
Sorry about that. I send you incorrect info. My bad. :smileyembarrassed:
Please post here for support information regarding your CAX modem:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
