akeele
Oct 26, 2021Star
NightHawk CAX 30 slows until Factory Reset or config restore
I have experienced this issue with this router since buying it at Costco in July 2021. My firmware is up-to-date with version 1.4.10.8. I do not have any special port forwarding or access control con...
akeele
Oct 26, 2021Star
You are recommending I post to a specialized Orbi forum described as "All things Cable Orbi, including updates, tips, & more" regarding my Nighthawk CAX30 cable modem?
Oct 26, 2021Guru - Experienced User
Sorry about that. I send you incorrect info. My bad. :smileyembarrassed:
Please post here for support information regarding your CAX modem:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
