phaedruspress
Oct 26, 2021Aspirant
Nighthawk CAX30 AX2700 Cable Modem Router; One Light is Solid Amber The Other Light is Solid White?
Modem/ router is connected to the TV via an Ethernet cable. Port 1. Sling TV on the TV works just fine however this light is solid Amber/ Yellow. When I connect a second Ethernet Cable Port 4 to a de...
- Oct 27, 2021
phaedruspress wrote:
>That's signifying its connecting at a 10/100mbps connection and not gigabit
Thanks for replying. That would sound about right then if I am not mistaken. Port 1 amber light. The TV is about 3 - 4 years old and I would not expect it to have GIGabit capabilities.
Most tv's aren't gigabit as streaming 4k only needs around 25-40mbps. so even a 100mbps connection will suffice and since its hardwired, you don't get the interference/network overhead of wireless. Glad to hear its working as it should :)
phaedruspress
I don't know why the image did not show. You can see it here One Light is Solid Amber The Other Light is Solid White?
- plemansOct 26, 2021Guru - Experienced User
- phaedruspressOct 27, 2021Aspirant
- plemansOct 27, 2021Guru - Experienced User
