cdahn's avatar
cdahn
Nighthawk CM 1100
How do I setup a 2.4G guest network? I'm being told this is required to run my pool automation and that my current network is a 5G.
  • Probably be better to ask on the google mesh forum for help with that.
  • plemans's avatar
    Well the CM1100 is a modem only device. It doesn't have wireless.
    So what actual router do you have?
    • cdahn's avatar
      cdahn
      I guess that probably explains it. I need to figure out how with my router, not modem. The router is a Google GJ2CQ model.
      • plemans's avatar
