craigkinsel
Feb 20, 2021Aspirant
Nighthawk CM2000 can't login
II couldnt pick CM2000 above...anyway... have a Nighthawk CM2000 modem. I like to look at the modem stats now and then to see if there any errors. I can no longer get access to the modem....
antinode
Feb 20, 2021Guru
> [...] I enter my password, and it looks back to my password again.
Perhaps you and the modem disagree about what the correct password
is.
> Also note I changed the password when I got the modem from the
> default.
Perhaps it got changed again somehow.
> I forget the default.
It's just possible that someone documented it someplace. You might
find some relevant information in a widely neglected resource:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read.
