NSSB
Apr 30, 2020Aspirant
Nighthawk Connection Options
I am considering purchasing a Nighthawk R7900P. My Spectrum 1G cable modem is upstairs in a small loft and I have a 16 port Netgear Gigabit switch beside the cable modem with ethernet feeds to most...
- May 02, 2020
NSSB wrote:
Almost all of our internet connections are initiated from the first floor of the house. What I would like to do is connect the cable modem to the Gigabit switch and then locate the R7900P on the first floor and connnect to one of the ethernet feeds on the first floor.
A more normal, arrangement, and one that I use, is to go:
> modem > router > switch
In that way the router gets to manage the traffic through the ports on the switch.
NSSB
Thanks for the reply. The Spectrum device is a cable modem only. It is not a router. It is made by Hirtron. I think the model number is E3IN2V1.
I am currently using using a Velop mesh network that is currently connected directly to the Spectrum cable modem. The primary Velop node is then connnected to my Netgear switch. I want to replace the Velop.
My original question still stands.
antinode
Apr 30, 2020Guru
> connected directly to the Spectrum cable modem. [...]
Thanks for not wasting everyone's time with a sloppy/incomplete
problem description?
You need to connect the (really-a-)modem to the router WAN/Internet
port, and the network switch to a router LAN port. Whether that's
possible/practical/convenient with your current cable arrangement is
another question.
- NSSBApr 30, 2020Aspirant
Thanks. Sorry for wasting your time
