NSSB
Apr 30, 2020Aspirant
Nighthawk Connection Options
I am considering purchasing a Nighthawk R7900P. My Spectrum 1G cable modem is upstairs in a small loft and I have a 16 port Netgear Gigabit switch beside the cable modem with ethernet feeds to most...
- May 02, 2020
NSSB wrote:
Almost all of our internet connections are initiated from the first floor of the house. What I would like to do is connect the cable modem to the Gigabit switch and then locate the R7900P on the first floor and connnect to one of the ethernet feeds on the first floor.
A more normal, arrangement, and one that I use, is to go:
> modem > router > switch
In that way the router gets to manage the traffic through the ports on the switch.
NSSB
May 02, 2020Aspirant
Thank you for the reply. I figured that was the best option. I wanted to place the Nighthawk router downstairs. Right now the cable for my Spectrum modem is running to the loft on my second floor.
The only way I am going to be able to do this is if I re-route the cable for the cable modem downstairs as well and move both the cable modem and the router downstairs.
michaelkenward
May 02, 2020Guru - Experienced User
Sounds like you have Ethernet cables running around the place. So you shouldn't have too much trouble plugging things in to get the best result, even though it may mean crawling around in the loft.
One important factor might be that it helps to get the wifi source in the middle of the property.
You seem to have that in mind with getting the R7900P on the first floor.
The R7900P should fill a reasonable space.
Hope it works out.
- antinodeMay 02, 2020Guru
> result, [...]Except for the minor problem of having the modem and the network
switch in one place, "the loft", and the router in another place, "the
first floor", which would necessitate running two cables between the
stuff in the loft and the router on the first floor.So, sure. Not "too much trouble" at all. (For anyone who doesn't
have to run the additional cable.)- NSSBMay 02, 2020Aspirant
I was in the attic today poking around and realized I have coax running to 4 or 5 rooms on the first floor that I used for Directv. I no longer have Directv.
This means I can move the cable modem and the new router to a single room downstairs. It will be fairly easy to connect the existing coax cable for the cable modem to the old Directv coax that is alreay in place. After I have the cable modem and the new router in the downstairs room, the only other task I have to perform is to run a 40' ethernet cable from one of the ethernet ports on the back of the router back up to my Netgear GS116 switch in the loft. I have too many ethernet feeds to move my switch anywhere else.
See anything missing with this approach? Any issue with a 40' ethernet run to my switch?
Thanks for all the help.
Nick
> room downstairs. [...]That should work. (A careful reader might note that I wrote, "two
cables", not "two Ethernet cables".)> [...] Any issue with a 40' ethernet run to my switch?
For Ethernet, anything up to 100m should be ok. What could go wrong?
A pessimist might check the signal stats on the modem at its old
site, for comparison with what happens at its new site. If there's a
problem with the new/different/extended (co-ax) cable, then more info
might make blame assignment easier.
