richardfrappel
Jul 25, 2021Aspirant
Nighthawk control od router
Trying to get Nighthawk to control router. It will not connect eventhough smartphone does connect. Tried going through settings. They were OK. Any ideas would be most welcome. Thank you.
richardfrappel
Jul 26, 2021Aspirant
Should have Latest firmware as I did a factory reset. I am connected to a local gateway (Valley Electric). The page just refreshes. I am able to connect to the router with the smartphone I am using (Samsung note 10 +) and all the other devices I have
Jul 26, 2021Guru - Experienced User
1. a reset doesn't "ensure the latest firmware". And many times with the r7000, it isn't on the latest.
2. what actual gateway is it? telling me the ISP doesn't tell me the gateway
3. its only the 1 device with issues? All the other devices work fine? that seems to indicate a device issue and not a router issue
