Shahsun
Oct 23, 2021Aspirant
Nighthawk cx80
I Just Bought Nighthawk CX80, Modem Router Build In. I Realize Internet Doesn't Works On Some Device. Laptop And Tv Works, But 2 phone And Tv Box It Doesnt.Doesn't. In Tv Box It Usually Says Less Con...
cscott1
Oct 24, 2021Guide
What speed service do you have is hooking them up to the 2.4Ghz band an option for you? Do the devices work when in the same room as the router? Things you can try turn off the wifi 6 and run off of the old wifi 5 K believe this is done by logging into the routers web interface routerlogin.net go to the wireless tab tick off the Enable AX. Other things move the modem/router to a more central location in you home or run Ethernet to the devices in the far rooms or look into wifi extenders or even use an older router you have laying around as an access point it may have better wifi than the built in wifi.
- ShahsunOct 24, 2021AspirantBoth 2.4 and 5 doesn't work. Both TV and TV box are at same place, but TV connects and TV box doesn't. All devices are in same room where router is located. The error message I received is error_connection_refuse
