Shahsun
Oct 23, 2021Aspirant
Nighthawk cx80
I Just Bought Nighthawk CX80, Modem Router Build In. I Realize Internet Doesn't Works On Some Device. Laptop And Tv Works, But 2 phone And Tv Box It Doesnt.Doesn't. In Tv Box It Usually Says Less Con...
Oct 24, 2021Guru - Experienced User
are you using wpa3?
I've seen a few devices struggle with wpa3.
You can try using wpa2.
like schumaku says, what devices are having the issues?
Wired/wireless?
Are you using smart connect?
Try disabling it and then seeing if it matters if those devices are connecting to 2.4ghz or 5ghz.
schumaku
plemans wrote:
are you using wpa3?
Yeah, however according to the UM thee is no WPA3 option. A difference to older Netgear routers is that it defaults to WPA2-PSK (AES), the mixed mode WPA2-PSK (AES) + WPA-PSK (TKIP) is disabled by default [what makes sense to avoid people reporting their Apple devices are reporting poor config].
