RonOL65
Feb 16, 2022Aspirant
Nighthawk Device Manager Symbol
In the Nighthawk app Device Manager section there are two symbols. One symbol indicates the wifi signal. What does the other symbol represent and indicate?
- Feb 17, 2022
Wired Ethernet?
What other symbol are you seeing? A screen capture would be helpful here.
Netgear has set up a community forum specifically for the Nighthawk App product. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Thank you.
Feb 17, 2022Guru - Experienced User
Wired Ethernet?
Thank you.
