Colettejb127
Jun 18, 2021Aspirant
Nighthawk EAX20
Hello, I have the nighthawk connected to my router by Ethernet, once it is up and running can I disconnect the Ethernet and move the nighthawk to a different room?
Jun 18, 2021Guru - Experienced User
No. If you're setting it up hardwired, you'd set it up in access point mode. If you're setting it up to be used wireless, you'd set it up in extender mode. And in that mode, it shouldn't be hardwired to the router.
Colettejb127
Thank you so much, truly appreciate the info
