dzachau
Oct 10, 2021Tutor
Nighthawk EX8000 and intermittent home network connectivity problem
My set up: I have a Nighthawk RAX200 router connected to a computer via ethernet connection in my home on the first floor. I have a second computer connected to the network by WIFI on the secon...
Oct 10, 2021Guru - Experienced User
what channel are you using for the wireless backhaul on the extender?
The RAX200 uses dfs channels and potentially you could be switching from a dfs channel to a standard channel because of dfs broadcasts.
dzachau
Oct 10, 2021Tutor
Channel 7
- dzachauOct 10, 2021Tutor
And, I am using 2.4 GHz only
- plemansOct 10, 2021Guru - Experienced User
for the backhaul?
the whole purpose of the EX8000 is the dedicated 5ghz backhaul.5ghz is much faster and doesn't suffer from as much interference as 2.4ghz.
If all you're using is 2.4ghz, its kind of an expectation that the link will be slow and suffer from interference.
OK. Thank you for the feedback. I will switch over to 5GHz and see if that results in better network connectivity with my other PC.
