Nhawkowasso
Jul 09, 2022Follower
Nighthawk fraggle attacks
Several days ago my connection started becoming virtually unusable. 20 to 25 percent packet loss after layer one. I looked in router logs and I see a ton of ddos fraggle attacks, about every 10 seconds. I've read up and some users say ignore them but this is causing my network to be inoperable. They are coming from port 67 from a nat'd 10. IP. Any suggestions??
1 Reply
- microchip8MasterFalse positives. NG is famous about that. It's flooding the resources of your system so disable logging. If that doesn't remedy the issue, completely disable DoS protection. You're not missing much
