Jamie242
Nov 28, 2021Aspirant
Nighthawk gaming router power cord
I have a nighthawk AC2300 model R700P. I lost my power cable in a move and need to get a replacement, don’t know which one would be best and can’t seem to find one on netgear website, and suggestion...
Nov 29, 2021Guru - Experienced User
netgear doesn't sell replacement power supplies. but you should be able to get one from amazon. You can find quite a few on there that are compatible.
If you want the "official" one. search for PA7000P . Otherwise you can use a 3rd party adapter that has the same specs.
Jamie242
Nov 29, 2021Aspirant
Thank you good sir
