roksakure
Dec 05, 2023Follower
Nighthawk internet but no wifi
Bought my nighthawk about a week ago. Was working good. Then the other night wifi stopped working. Netgear tech couldn't figure out the problem. Any ideas what the issue could be?
schumaku
Dec 06, 2023Guru - Experienced User
Check this: How do I turn my NETGEAR router’s wireless radios on and off using the WiFi On/Off button? - the most common issue if any.
michaelkenward
Not helped by the fact that it isn't obvious on the device itself that the indicator LED is also a switch.
Cat owners, and parents of toddlers, should also pay particular attention to this switch. These animals can interfere with nice glowing lights.
- schumakuDec 06, 2023Guru - Experienced User
michaelkenward wrote:Not helped by the fact that it isn't obvious on the device itself that the indicator LED is also a switch.
The industrial design massively changed - it's much more than a hard to see small LED button now.
michaelkenward wrote:Cat owners, and parents of toddlers, should also pay particular attention to this switch. These animals can interfere with nice glowing lights.
Sure, the more obvious it becomes 8-)
- michaelkenwardDec 06, 2023Guru - Experienced User
Neat. If that is the model that roksakure has purchased.
Then again, the design of that thing is "ugly as buggery", to use an old English saying.
My MR90 doesn't even have an on/off switch for the wifi. Much nicer design though.
