iruma77
Sep 28, 2022Follower
Nighthawk keeps factory-resetting after every power outage
So this started a few months back when we had a power outage at home for first time for a long while. Nighthawk got reset to factory settings itself when power's back and I had to set it up again. I ...
michaelkenward
Sep 28, 2022Guru - Experienced User
iruma77 wrote:
But recently we get power outages more often, and even if the router is on latest FW, every time it gets factory-reset after power is back.
It won't fix the immediate problem, but you can make life a bit easier by saving the configuration and then reload it when the device resets itself.
Have you thought of getting an uninterruptible power supply (UPS)? Might also reduce the possibility of damage caused by power constantly going on and off.
