gene_mo
Aug 26, 2021Aspirant
Nighthawk Loses WiFi signal
I have had this Nighthawk since 2015 and it was bullet proof until I installed Amour. Then, nothing but problems even after I turned Armour off and tried to uninstall. My router is right next to my ...
Aug 26, 2021Guru - Experienced User
Press the reset button in back of the router for 10 seconds then release. Connect a wired PC to the router and setup from scratch.
- gene_moAug 26, 2021Aspirant
Thanks. Do you have experience with this issue and the factory reset option solves it or is this just an answer to my question about how to do a factory reset?
Thanks again for the help.
