gene_mo
Aug 26, 2021Aspirant
Nighthawk Loses WiFi signal
I have had this Nighthawk since 2015 and it was bullet proof until I installed Amour. Then, nothing but problems even after I turned Armour off and tried to uninstall. My router is right next to my ...
Aug 26, 2021Guru - Experienced User
Press the reset button in back of the router for 10 seconds then release. Connect a wired PC to the router and setup from scratch.
gene_mo
Thanks. Do you have experience with this issue and the factory reset option solves it or is this just an answer to my question about how to do a factory reset?
Thanks again for the help.
