PIJ1000's avatar
PIJ1000
Nighthawk M1 - no access to webadmin
Hi All,
I have changed the IP address of the router to 192.168.1.2 and since this time I can't access the web admin. I get the error message that it has been to often redirected. Is it possible to make a factory / hard reset without accessing the webadmin?
Thanks a lot for your help.
  • oh just mea culpa!!! I should read carefully the manual, I have found the hard reset.
    • myersw's avatar
      myersw
      Master
      No biggie. Glad you figured out on your own. That is the way we learn.
