Rob517
Nov 03, 2021Follower
Nighthawk M1 Wifi Channels Won't Change
Hi All, I just setup a new M1 and the interface will allow me to select a new WiFi channel (2.4Ghz) but I cannot "APPLY" it. The button turns red and will not me click it. It will only allow it...
- Nov 03, 2021
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
Nov 03, 2021Guru - Experienced User
Thank you
