MisterB1959's avatar
MisterB1959
Nighthawk M2 unlocking help !!
I have been trying for well over 12 months to get MR2100 unlocked from EE - they emailed netgear (they said, over 12 months ago) and emailed them again 2 sweeks ago - i feel as though i am getting nowhere. i bought the device around 2 years ago and although i am really pleased with it and it gives me excellent connectivity - the fact that i cant use it on another network to get better coverage at times when travelling is more than frustrating.
can anyone help please, thanks
  • Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
    You might contact a forum moderator for additional help and information regarding this:
    DarrenM olympos1625
    Thank you
  • FURRYe38's avatar
    DarrenM olympos1625
    Thank you
  • michaelkenward's avatar
    michaelkenward
    You trust EE?
    As well as going to the right but of this community, if you haven't done so already, I'd throw this at the EE community.
    Unlocking your device - The EE Community
    Unlocking mobile devices is usually down to the service supplier, in this case EE.
