Ibmpete
Aug 27, 2021Follower
Nighthawk mesh 6 dropping Alex a devices
Alexa loses connection w Kada devises on mesh 6 system
michaelkenward
Aug 28, 2021Guru - Experienced User
If you are looking for help, you should start by providing a descrption of the problem that has enough clues for people to understand.
You should also pick the right section for whatever unknown Netgear device you own. Mesh 6 could be many things. It isn't though, one of the Nighthawk WiFi Routers covered in this bit of the community.
