shobhanks
Dec 25, 2021Follower
Nighthawk mesh mk63 with c6900
Not able to connect nighthawk mesh mk63 with c6900. It says “Router not supported”. The Nighthawk app does not support your router model.
Dec 25, 2021Guru - Experienced User
You need to turn OFF router mode on the C series modem and then setup the MK system.
Try setting up the MK system with a web browser and PC connectafd to the MR.
Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
