Krazyking06
Jan 25, 2022Aspirant
Nighthawk mesh mr60 dead
The actual mr60 not the satellite just up and died, it completely stopped working. I tried plugging it into a different socket, trying a different cord, and nothing. I have hardware warranty but not t...
- Jan 25, 2022
With contacting support, you can still start the rma process through the support site. If they contact you, they might try to charge you but if its a hardware warranty issue and not just fixing a setting, it doesn't cost. I usually make them admit it up front just in case.
https://kb.netgear.com/1162/How-can-I-get-a-Return-Material-Authorization
Jan 25, 2022Guru - Experienced User
Is the power light on?
did you try swapping the power supply on the satellite with the router?
You should still be able to start the warranty process through support if its dead.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
- Krazyking06Jan 25, 2022AspirantI did swap the power blocks and the light still wasn’t on, and the chat and phone supports are both expired except the hardware warranty
- plemansJan 25, 2022Guru - Experienced User
