Krazyking06
Jan 25, 2022Aspirant
Nighthawk mesh mr60 dead
The actual mr60 not the satellite just up and died, it completely stopped working. I tried plugging it into a different socket, trying a different cord, and nothing. I have hardware warranty but not t...
- Jan 25, 2022
With contacting support, you can still start the rma process through the support site. If they contact you, they might try to charge you but if its a hardware warranty issue and not just fixing a setting, it doesn't cost. I usually make them admit it up front just in case.
https://kb.netgear.com/1162/How-can-I-get-a-Return-Material-Authorization
Krazyking06
I did swap the power blocks and the light still wasn’t on, and the chat and phone supports are both expired except the hardware warranty
Jan 25, 2022Guru - Experienced User
