SteveBen
Oct 08, 2021Guide
Nighthawk Mesh Router Can't Connect to Netflix, AppleTV or Prime
I think this is my model, but it's a brand new (2021) wifi 6 Nighthawk router. I bought it because I have a four-story house with a TV and a Peloton on the top floor and TV's on the other three. My C...
Oct 08, 2021Guru - Experienced User
What model router do you have? The R7800 mentioned at the bottom is NOT a wifi 6 router.
Do you have a RAX model router? IF so, then Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH WiFi 6 router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
If you have a NH MESH MK system, Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
- SteveBenOct 08, 2021Guide
- FURRYe38Oct 08, 2021Guru - Experienced User
Please post about this here then:
Thank you.
