edukehtoer
Jun 10, 2021Aspirant
Nighthawk mesh Wi-Fi 6 system
I have a NightHawk mesh 6 system newly installed. (I cannot find technical specifications on the model list that match. The Second satellite closest to the garage has a very weak signal on my se...
michaelkenward
Jun 11, 2021Guru - Experienced User
The Second satellite closest to the garage has a very weak signal on my security camera there. It's about 40 feet really, just the next room really even though there's a 4' space between the garage in the house.
Is there any way I can strengthen the signal coming out of that second satellite?
Once us usually enough:
M60 Connection Weakness - NETGEAR Communities
- edukehtoerJun 11, 2021Aspirant
Well I don't know how it got on there twice. I am a new user so maybe I hit something twice. What I can't find is a way to delete one of them. Would you know how?
- michaelkenwardJun 11, 2021Guru - Experienced User
Stuff happens.
I wanted to avoid anyone else getting lost in the discussion, especially given that your information was a bit wonky and was probably not posted in the best section for whatever it is that you own.
