jlh273
Jan 27, 2022Follower
Nighthawk mesh Wi-Fi 6
I have set up my router system with no problems and I am getting Internet. The internet speed will not register on my app. How can I fix this so I can test my speed? I have updated the app also already.
Your not the first to report the speedtest in the app not working.
When it does work, its not trustworthy on speeds.
so I usually don't recommend using. I recommend using the speedtest website or app on one of your devices.
And to test with a hardwired devices since that'll test your fastest speeds.
What model MESH system do you have?
