NanaNickToot
Dec 17, 2020Tutor
Nighthawk Mesh WiFi 6 AX1800 Not Working with LG Smart TV
Just set up a Wifi mesh 6 system and everything is working good except for some things on my LG smart TV (LG webOS TV UM8070AUB). TV is connected to wifi and plays Youtube and Apple tv apps perfectly. However after I first set up the wifi6, Amazon prime and Netfliz would not start on the TV and kept giving an error (1024 maybe?), so I ended up removing the apps in hopes of reloading them through the LG Content Store, but then the LG content store errored out on start with a -324 code. Anyway at this point I called up (or chatted) with both an LG tech and a Net gear tech but was not able to get anywhere. Troubleshooting included rebooting, turning off quick start and then finally a full factory reset on the TV. Still no luck. Any ideas?
Followed the above thread for my specific Gateway and eventually succeeded. Thanks for help!
Which mesh system did you buy? AX1800 is a speed.
What firmware is on it?
What modem/gateway is it connected to?
Sticker on packaging says: MK63-100NAS
on my phone Netgear Nighthawk app the Router is called: MR60
the satelites are called: MS60
V1.0.6.102
Arris NVG443B
the arris is a modem/router combo device.
Do you have it in bridge mode to prevent a double nat?
Or the netgear in access point mode?
https://kb.netgear.com/30186/What-is-Double-NAT
