JVALENCI
Jul 05, 2021Aspirant
Nighthawk Mesh Wifi 6 compatibility with Xfinity
I want to use my own wifi modem router instead of the Xfinity supplied equipment. Is the Nighthawk Mesh Wifi 6 system - model AX1800 compatible with Xfinity and able to fully replace the Xfinity pro...
- Jul 06, 2021
> [...] MK62 or MK63S (that is all what I can see [...]
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get some. Read.> [...] in which case I would still need the Xfinity Modem...
To use a plain router, you'd need _some_ compatible modem.
antinode
Jul 05, 2021Guru
> [...] Nighthawk Mesh Wifi 6 system - model AX1800 [...] Nighthawk
> AC1900 [...]
None of those is a model number. "AX1800" and "AC1900" are wireless
speeds.
> [...] Neither the box nor the specifications of the AX 1800 list
> Xfinity compatibility.
If it's a router, and not a cable modem (or a cable modem+router),
then the ISP (cable provider) would not matter. Without seeing the
actual model numbers, it's tough to know what you're looking at.
Look for "Model" on the product label, or look more closely at the
box.
- JVALENCIJul 06, 2021Aspirant
Reference to the AC1900 item would be model C7000. Box clearly describes it as a WiFi Cable Modem Router.
Reference to AX1800 model would be Nighthawk MK62 or MK63S (that is all what I can see in the picture I have of the box) and I don't see any reference to "Modem", may be only a WiFi Router unit -- in which case I would still need the Xfinity Modem...
- antinodeJul 06, 2021Guru
