JVALENCI
Jul 05, 2021Aspirant
Nighthawk Mesh Wifi 6 compatibility with Xfinity
I want to use my own wifi modem router instead of the Xfinity supplied equipment. Is the Nighthawk Mesh Wifi 6 system - model AX1800 compatible with Xfinity and able to fully replace the Xfinity pro...
- Jul 06, 2021
> [...] MK62 or MK63S (that is all what I can see [...]
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get some. Read.> [...] in which case I would still need the Xfinity Modem...
To use a plain router, you'd need _some_ compatible modem.
JVALENCI
Jul 06, 2021Aspirant
Reference to the AC1900 item would be model C7000. Box clearly describes it as a WiFi Cable Modem Router.
Reference to AX1800 model would be Nighthawk MK62 or MK63S (that is all what I can see in the picture I have of the box) and I don't see any reference to "Modem", may be only a WiFi Router unit -- in which case I would still need the Xfinity Modem...
antinode
Jul 06, 2021Guru
