Tommynba
May 04, 2022Follower
Nighthawk model AC1900 smart Wi-Fi router, how do I recover Wi-Fi password?
How do I breach the firewall?
michaelkenward
May 05, 2022Guru - Experienced User
You don't.
Start with the problem. You want to recover Wi-Fi password? If you can't remember it, then the choices are limited.
The easiest option is probably to use the browser graphical user interface (GUI). (The manual explains how to do that.)
Unless you changed it, and also forgot that password, the access details are on the device.
Go here in a browser:
http://routerlogin.com/index.htm
The wifi password is on the page in front of you.
Alternatively, the desktop genie for your operating system has the same details.
genie | Product | Support | NETGEAR
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
