laceoak's avatar
laceoak
Nighthawk model R6700.3 Red indicator light
When using my PC, the #1 device indicator light on the router is white.  Normally, when the PC is in sleep mode, that indicator light goes out.  Now it won't go out...it changes to red.  Does anyone ...
  • microchip8's avatar
    microchip8
    May 08, 2020
    No, the colored light (red/orange) indicates there's a connection at 10 or 100 Mbps. White indicates a 1 Gbps connection. The only conclusion is that the network chip is active while in sleep mode. As I said, this is needed for WoL. My NAS also goes into red color when I turn it off and when I want to turn it back on, I just send a magic packet (WoL) to it and it boots up
