chojt's avatar
chojt
Tutor
Oct 21, 2021
Nighthawk MR60 can't connect to 5GHz
For some reason, my PC refuses to connect to the 5GHz network. I know it's not my PC issue because it actually connected to the 5GHz at first, but then changed to 2.4GHz by itself for no reason. Every other device connected to it just fine.
I've been trying to fix it by changing settings from the routerlogin.net page, but without the ability to set up separate SSIDs or even just disable 2.4GHz, I'm at a loss. Please help!
  • plemans's avatar
    What pc is it?
    some have a setting for "prefer 5ghz" in the device manager settings.
    The MR60 allows bandsteering for devices to switch between 2.4ghz/5ghz based off its needs/distance from the router.
    • chojt's avatar
      chojt
      Tutor
      Armaggeddon Falcom 3060-R5. I'm guessing I have to change something to the "Intel(R) Wi-Fi 6 AX200" under Network adapters?
  • FURRYe38's avatar
    For your MK future needs, Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
    Thank you.
