ladamo
Oct 13, 2021Aspirant
Nighthawk MR60 setup & administration
I have an MR60 router + 2x MS60 satellites. The automatic installation ended with my gear operating on the same channels as my neighbors in both 2.4GH & 5GH bands. In order to get into administratio...
michaelkenward
Oct 14, 2021Guru - Experienced User
plemans has asked you some key questions. But the MR60 is not one of the Nighthawk WiFi Routers covered in this section of the community.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
Those things are very different from the standard Netgear routers covered in this section.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
ladamo
Oct 14, 2021Aspirant
Thanks for keeping watch over newbies.
You've explained why MR60 doesn't appear in the list of models.
I'll follow up.
